i m using ubuntu server 18.04 and i have openjdk-11-jre installed on the system
I need help with it not Detecting my java
- 380 Views
- Last Post 15 July 2019
Minecraft-dev-server
posted this
09 July 2019
Mike
posted this
10 July 2019
If you run java -version
what's the output?
Also you should use openjdk-8-jre-headless
for Minecraft.
posted this
11 July 2019
here is the out put openjdk version "1.8.0212" OpenJDK Runtime Environment (build 1.8.0212-8u212-b03-0ubuntu1.18.04.1-b03) OpenJDK 64-Bit Server VM (build 25.212-b03, mixed mode)
posted this
11 July 2019
posted this
11 July 2019
Mike
posted this
12 July 2019
Have you restarted the server since installing java?
posted this
12 July 2019
ya
Mike
posted this
15 July 2019
And what's the output of whereis java
