Forums Archived
Find the new forums here
Instances using TCP+UDP duplicating UDP rules instead
  • 326 Views
  • Last Post 15 February 2021
  • Topic Is Solved
AbhorrentJoel posted this 05 February 2021
OS Name/Version: Ubuntu 20.04.2 LTS (fresh install since a few days)
Product Name/Version: AMP (apt version 2.1.0.2 - upgraded from 2.1) - NOTE: I am using Docker for instances, but it seems to occur regardless.
Problem Description: When creating a new instances, AMP appears to be duplicating UDP ports in the case where TCP+UDP is specified.
I have two instances created, for Minecraft and 7 Days to Die, and the port is duplicated - 4 bottom rules:
root@[redacted]:~# ampinstmgr dumpports amp
[Info] AMP Instance Manager v2.1.0.2 built 03/02/2021 00:33
[Info] TCP/2223 (AMP:ADS01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] UDP/12820 (AMP:ADS01:ADSModule.Network.MetricsServerPort)
[Info] TCP/2224 (AMP:Minecraft01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] TCP/2225 (AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber)
[Info] TCP/8766 (AMP:SevenDays01:SevenDaysModule.Server.WebServicePort)
[Info] TCP/27016 (AMP:SevenDays01:SevenDaysModule.Server.TelnetPort)
[Info] UDP/25565 (AMP:Minecraft01:MinecraftModule.Minecraft.PortNumber)
[Info] UDP/27015 (AMP:SevenDays01:SevenDaysModule.Server.ServerPort)
For example, the output from the firewall for the 7 Days to Die instance:
root@[redacted]:~# ufw status numbered | grep SevenDays01
[ 8] 2225/tcp                   ALLOW IN    Anywhere                   # AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber
[ 9] 8766/tcp                   ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.WebServicePort
[10] 27016/tcp                  ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.TelnetPort
[11] 27015/udp                  ALLOW IN    Anywhere                   # AMP:SevenDays01:SevenDaysModule.Server.ServerPort
[22] 2225/tcp (v6)              ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:FileManagerPlugin.SFTP.SFTPPortNumber
[23] 8766/tcp (v6)              ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.WebServicePort
[24] 27016/tcp (v6)             ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.TelnetPort
[25] 27015/udp (v6)             ALLOW IN    Anywhere (v6)              # AMP:SevenDays01:SevenDaysModule.Server.ServerPort
Obviously, this results in it being impossible to connect where TCP is required. I have a feeling that it worked in AMP v2.1, yet I cannot confirm.
  • Install AMP v2.1 (with Docker) on a fresh Ubuntu 20.04.2 LTS install
  • Upgrade to AMP v2.1.0.2
  • Create instances for games which use TCP+UDP (7 Days to Die, Minecraft, etc.)
  • Forced an upgrade of AMP instances using no-cache option
  • Removed ampinstmgr apt package, cleaned apt cache, and reinstalled
  • Deleted and created new instances
AbhorrentJoel posted this 11 February 2021
Fixed in v2.1.0.6. Mentioned here.
Painwithin posted this 15 February 2021
This issue still seems to be apparent in 2.1.0.6 mine was working fine until updating now its duplicating UDP on ports "mainly game server ports".
AbhorrentJoel posted this 15 February 2021
It was working fine for me after the update to 2.1.0.6. I am not sure if it is necessary to create new instances in order for this to work - I would have guessed not, but cannot confirm.
Just ensure you have updated ampinstmgr via your distro's package manager, and preferably update AMP instances using the nocache option:
ampinstmgr --nocache upgradeall
I am currently on the Nightly build due to fixes applied to the Generic module, but it is seemingly all working fine for me there.
Close
