OS Name/Version: Ubuntu 18.04.2
Product Name/Version: AMP Release "TITAN" v1.8.2.2, built 05/07/2019 11:38 / ADS Core Module
Problem Description: After working to get the internal AMP web server switched to use HTTPS/SSL you are unable to use the Passthru Management function to manage child Instances. An Error is thrown stating an HTTP request error. IP address and usernames have been removed.One thing I did notice is that in both the logs and ampinstmgr that the addresses for the servers show in http.
UI Error:
Http Request An error occurred while sending the request Thrown by the 'Core' plugin while performing the 'GetAPISpec' method. Related Link: Advanced Details at Net.WebOperation.Run () at Net.WebCompletionSource`1[T].WaitForCompletion () at Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) at ADSModule.WebMethods.Servers (m.Http.IHttpRequest request, String id, String REQ_RAWJSON)
Except from Logs:
[18:15:52] [ADS:ampuser Activity] : Managed remote instance Minecraft at http:/// [18:15:52] [Auth:ampuser Activity] : Authentication token for ampuser requested by ManageInstance on behalf of ampuser [18:15:52] [ADS:Anonymous Error] : Failure to make API call to Minecraft (http:///) - retried 10 times : An error occurred while sending the request [18:15:52] [Core:Anonymous Error] : [0] (HttpRequestException) : An error occurred while sending the request [18:15:52] [Core:Anonymous Error] : at ADSModule.WebMethods.Servers (m.Http.IHttpRequest request, String id, String REQ_RAWJSON) [18:15:52] [Core:Anonymous Error] : 1 (WebException) : Error getting response stream (ReadDoneAsync2): ReceiveFailure [18:15:52] [Core:Anonymous Error] : at Net.WebOperation.Run ()
ampinstmgr -l output:
[Info] Starting Ins[Info] AMP Instance Manager v1.8.2.2 built 05/07/2019 11:39 [Info] Release spec: Release - built by CUBECODERS/BuildBot on CCL-DEV Instance ID │ Module
│ ADS Instance Name │ ADS01 Friendly Name │ ADS01 URL
│ http://:/ Running │ Yes Runs in Container │ No Start on Boot │ Yes AMP Version │ 1.8.2.2 Release Stream │ Mainline Data Path │ /home/AMP/.ampdata/instances/ADS01Instance ID │ Module │ McMyAdmin Instance Name
│ Minecraft Friendly Name │ Minecraft URL │ http://:/ Running │ Yes Runs in Container │ No Start on Boot │ No AMP Version │ 1.8.2.2 Release Stream │ Mainline Data Path │ /home/AMP/.ampdata/instances/MinecraftInstance ID │ Module │ Minecraft Instance Name
│ Minecraft01 Friendly Name │ Minecraft Bedrock Edition URL
│ http://:/ Running │ Yes Runs in Container │ No Start on Boot │ No AMP Version │ 1.8.2.2 Release Stream │ Mainline Data Path │ /home/AMP/.ampdata/instances/Minecraft01
Stopped all Instances
Followed instructions on wiki for using HTTPS: CubeCoders/AMP Wiki Setting up HTTPS with AMP
Started Instances
Verified the instance.json
Verified changes in conf file: .ampdata/instances/*/AMPConfig.conf
Verified sites can be accessed independently via direct address or IP
