OS Name/Version: CentOS release 6.9 (Final) Linux 2.6.32-696.3.1.el6.x8664 #1 SMP x8664
Product Name/Version: [Info] AMP Instance Manager v1.5.0.0 built 02/11/2017 13:55 [Debug] Release spec: Release - built by CUBECODERS/BuildBot on CCL-DEV
Problem Description: After upgrading to 1.5.0.0 from 1.4.8.2 AMP fails to start i.e. no webserver gets spawned.
Looking into /home/AMP/.ampdata/instances/MCMA/LastAMPException.txt I see the following error:
[Error] --- Begin Exception Data ---
[Error] OS: Linux (x86_64/None)
[Error] Module: McMyAdminModule, Version: AMP 1.5.0.0
[Error] Instance ID: b692b0b9-c54e-484b-8276-d2b6df90ff69
[Debug] Starting process /bin/uname
[Debug] Working Directory: /home/AMP/.ampdata/instances/MCMA
[Debug] Arguments: -a
[Debug] Started process with ID 1541
[Error] Linux butler.cpmt.ca 2.6.32-696.3.1.el6.x86_64 #1 SMP Tue May 30 19:52:55 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
[Error] [0] (NullReferenceException) : System.NullReferenceException: Object reference not set to an instance of an object
at MinecraftModule.PluginManager+<>c.<discoverplugins>b__20_1 (System.Collections.Generic.KeyValuePair`2[TKey,TValue] p) [0x00007] in <87d20f87aea047a787face7d4e32bd5c>:0
at System.Linq.Enumerable+WhereSelectEnumerableIterator`2[TSource,TResult].ToArray () [0x0001d] in <596ca682c6c442a5858eb8ee681bbe27>:0
at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <596ca682c6c442a5858eb8ee681bbe27>:0
at MinecraftModule.PluginManager+<discoverplugins>d__20.MoveNext () [0x0025c] in <87d20f87aea047a787face7d4e32bd5c>:0
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Runtime.CompilerServices.AsyncMethodBuilderCore+<>c.<throwasync>b__6_1 (System.Object state) [0x00000] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context (System.Object state) [0x00007] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00071] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00000] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () [0x00021] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading.ThreadPoolWorkQueue.Dispatch () [0x00074] in <3574b7750bbd4f3481d1561b74d01b33>:0
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () [0x00000] in <3574b7750bbd4f3481d1561b74d01b33>:0
Stop AMP Start AMP after upgrade
Actions taken to resolve so far: None. I don't even know where to start on this one.3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>3574b7750bbd4f3481d1561b74d01b33>87d20f87aea047a787face7d4e32bd5c>596ca682c6c442a5858eb8ee681bbe27>596ca682c6c442a5858eb8ee681bbe27>87d20f87aea047a787face7d4e32bd5c>
